Wow!markpk wrote: But like you, I am having CC's other than 7 and 10 continue playing even when the automation-enable button on the MIDI Track is un-checked. I've used DP for over 20 years - this is NOT normal behavior. And the tech support guy confirmed that this should not be happening.
Thank you for this info, Markpk.
I will also open a techlink at MOTU's site. Perhaps I was not that naive, after all...
I am actually more surprised about the lack of responses and interest about this topic / thread...markpk wrote:So ... I hope we'll have an answer soon. Honestly, I'm surprised no one else has encountered this weird behavior.
I know we have a few experts who use sophisticated CC stuff all the time, but apparently this has been of no interest to them
Agreed. It took me a few weeks to master it (automap and advanced mode), but it was so worth it. I don't know how I could work without itmarkpk wrote:On a related note - I also have a Novation controller (the Zero SL MKII). The thing is truly a wonder, although it has some quirks and a steep learning curve.
I haven't really tried it, but the few tests I did with Stylus it worked fine.markpk wrote:Question: I wanted to ask you if you've been able to use the controller successfully with Stylus RMX. That's the one plug-in that has been problematic for me. Have you got it to work? (I've opted to use RMX as a "MIDI client" instead, which is working out well, although I'd rather have the automap-wrapped version running.)
In general, I always prefer to either, use advanced mode (with my own mappings), or tweak the automap settings for any given plug/instrument. I have not found even ONE automap setting I like.
For instance, all the automap settings for Waves are really bad. I ended up deleting them and doing my own from scratch.
Is there a particular problem you are having with Novation/Stylus? Tell me about it, perhaps I could help
It will be MY PLEASURE! Let's compare notes about MOTU's responses to our techlinks. The moment you or I hear from them, let's post it here.markpk wrote:Let's keep in touch about the crazy MIDI CC behavior. I really want to get this solved.
DP would be a million times more useful (for this) if it worked like the manual implies!
Thanks for your interest, MarkPk
