Hi i recently bought DP6 and am having a rather frustrating issue with it. It appears the bundled plugins bassline, polysynth etc have this issue where it cuts the end of the note off. like there is a gate on it but to my knowledge there are no effects on it it's a dry signal. even more confusing is when i add say an AU reverb effect the tail of the reverb is gated and cuts off the same time as the note ends abruptly which is a rather annoying issue. is there something misconfigured here? im sure there is a really simple answer i have overlooked? (or at least i hope...) another thing is that external instrument plugins do not suffer this issue and the reverbs do not cut short even if the note does.
look forward to your wisdom... thanks
Jon
DP6 bundled plugins strange gate like issue
Re: DP6 bundled plugins strange gate like issue
Hi, little late to the game here but I'm just encountering the same problem, and found some explanations here:
http://www.motunation.com/forum/viewtop ... &start=135
