Bounce MIDI to disk VE Pro/EW PLAY/DP 7.2?
hrw
Post by hrw »
i'm using VE Pro on my slave Quad Core 2 x 2.66 w/16 GB RAM and am using PLAY in several instances of VE PRO. Playback is generally fine into my host machine w/DP7.2. But when i go to bounce the MIDI their are a lot of glitches and stutters. The Kontakt 4 stuff seems to bounce ok though...?
Anyone had this issue and what can i check off the list that might be causing it?
i also found glitchiness and drop outs when i go to freeze tracks. is this because PLAY is still not 64 bit and my machines are not fast enough? In some ways i had less issues with Bidule just running on single machine (2 x 2.66, Dual Core Mac Pro) although playback could sometimes get overloaded. I want to get the best out of this setup without work arounds anyone?
i've got DP prefs set to playing all VI's in real time.
Computer/s: OSX 10.8.3
2 x 2.66 GHz Mac Pro Quad-Core Intel Xeon w/ 16GB RAM,
DAW:DP8.05
Hardware: Apogee Duet
VI's/Plug-ins:
Kontakt 5.1, EW PLAY Libraries and a
million others.
hrw
Re: Bounce MIDI to disk VE Pro/EW PLAY/DP 7.2?
Post by hrw »
anyone?
DAW:DP8.05
VI's/Plug-ins:
million others.
