NI plugs still broken in 6.01 (not all?)
JMSchur
Post by JMSchur »
Just installed the DP 6.01 update on my PowerMac G5 and the NI plugins are still broken. Now, the NI plugs pass the MOTU check but as soon as I try to instantiate any NI plugin, DP crashes. Really frustrating!
PowerMac G5 Dual 2.5Ghz/4.5GB,(10.5.4); 2408 MkII w/424e; MIDI ExPress USB; MacBook Pro 17", 2.6Ghz/4GB,(10.5.4)
groove
Re: NI plugs still broken in 6.01
Post by groove »
The same here. I went back to DP 6.0 and the workaround of using "MAS AudioUnit Support.bundle" version 1.6.1 of DP 5.13.
I've tried DP 6.01 with the two bundles - ie "MAS AudioUnit Support.bundle" version 1.7.0 from DP 6 and 1.6.1 from DP 5.13 but got all crashes and graphical problems with NI stuff as well as Stylus RMX.
UAD 5.0 and the latest Vienna worked well with "MAS AudioUnit Support.bundle" version 1.7.0 wich is a good start.
Hope the next fix - maybe DP 6.02 - will do the trick.
iMac Pro 3 GHz 10-Core Xeon E5, 64GB ram OS X 10.15.7, UA Apollo 8 Quad + Satellite Quad, UA 2192, Waves V12, LASS Full, VSL, Korg MS-20, Elektron A4, Moog SlimPhatty, NI Komplete13, ROLI, Soundtoys 5, Arturia V Collection, GForce Oddity, Serum.
motuhelper
Post by motuhelper »
I'm running Reaktor 5 and Absynth just fine.
The latest Stylus works fine too with dp6.01.
Tonio
Post by Tonio »
K3 is working here, no problems that I can tell. I only used K3 for about 2 weeks, so still wrapping head around it , but it loads and can record/play etc..
T
groove
Post by groove »
motuhelper wrote:I'm running Reaktor 5 and Absynth just fine.
Are you on Intel or PPC?
motuhelper
PPC G5 Dual 2.7
OSX 10.4.11
6 Gigs of RAM
JMSchur
Post by JMSchur »
On a PPC based machine?
slicerecords
Post by slicerecords »
still broken here too,
really pissed
running 10.5.4
on a PPC G5 dual 2.5ghz
it seems it works in tiger 10.4.11 reading others posts........
if MOTU had a face I would slap it right now. this is just unprofessional. I support this company, and was patient for almost 2 months, and no fix. just plain ignorance on their part.
PowerMac G5 Dual 2.5Ghz, 6GB RAM, 10.5.8, DP 7.11, 828mk3, Waves Platinum V7, Komplete 5, VSL Special Edition Plus Byndle, URS Everything Bundle...
JMSchur
Post by JMSchur »
slicerecords wrote:still broken here too,
really pissed
running 10.5.4
My sentiments exactly. I've been using DP since version 2. This is the first time I truly regret upgrading. I wish I would have spent the money switching to Logic.
really pissed
running 10.5.4
Which NI plugs are broken for you? I have found some of the older ones are going to have problems. My FM7 opens with a totally blank white window... however oddly enough it works-- you just can't see the UI. (Not useful I know). Also KontaktPlayer 2.2.4 won't work either and crashes. I can use both of those standalone with Soundflower, but it's a little bit of a hassle. My point is though that some of the older NI stuff might not make it and it might be necessary to upgrade to later versions.
:shock: I understand your frustration... but...
JMSchur
Post by JMSchur »
really pissed
running 10.5.4
As for me: I'm using FM8, Akoustic Piano, Massive, Absynth 4, and Reaktor5. All are latest versions. They are completely broken with the DP6.01 version of AudioUnit Support bundle; and, with DP5 AU Support bundle, they work but are unusable due to graphic anomalies. I can however, still use them in DP6.0 with the old DP5 AU Support bundle.
JMSchur wrote:As for me: I'm using FM8, Akoustic Piano, Massive, Absynth 4, and Reaktor5. All are latest versions. They are completely broken with the DP6.01 version of AudioUnit Support bundle; and, with DP5 AU Support bundle, they work but are unusable due to graphic anomalies. I can however, still use them in DP6.0 with the old DP5 AU Support bundle.
Do you mind if I ask: when you say "completely broken," do you mean that they crash DP... or do they do something else? I'm wondering why FM7 doesn't crash DP (there's a missing GUI of course!) but FM8 does?
JMSchur
Post by JMSchur »
Crash! As soon as I attempt to instantiate one of the NI plugs, the beach ball spins for a few seconds and... poof!
Man... that's a bummer... I feel your pain. This needs resolution from either NI or MOTU quickly. I'm using my NI stuff standalone as a workaround, but it just causes me to avoid it more than anything. I bought VI ONE not too long ago which runs on Kontakt Player2 and I haven't been able to use it as a plug-in since-- which means my Plugsound Pro is getting more use these days.
slicerecords
I have all the latest versions of NI's Komplete Bundle, in which the only plug-in that does work is Kontakt 3. Everythng's updated to the latest versions.
The GUI does not load and an error message pops up. NI has said this error message is a DP Error message, because it is not an error message they were familiar with.
C'mon motu......and ni.......get it together.
