It is currently Wed Feb 21, 2018 6:03 am
Text Size
Track Group bug?
Track Group bug?
Postby stringtheory » Wed Feb 14, 2018 11:23 am
let's say i create an edit track group of 3 tracks, each with equal-length soundbites that begin and end at the same time. when i select the top soundbite, the lower 2 are not selected, and when i select either of the lower 2, they are both selected but not the top one. UNTIL i make splices in the soundbites - after that, as long as i select a portion that does not contain either the beginning or end of the original soundbite, all 3 tracks are selected together. but still, selecting the beginning portion or the ending portion doesn't select the whole group.
i'm finding it a little hard to describe this behavior. it's not consistent, but it's frequent... and i don't understand it. i can shift-click as a workaround, but something is wrong, yes?
27" iMac 3.2GHz (late 2012), 24G RAM, UAD Apollo Duo TB, MTPAV USB, DP9.51, OS10.12.6 (also late 2012 MBP, 2.9GHz, 16G RAM, Apollo Twin Duo TB)
stringtheory
Re: Track Group bug?
Postby mrgkeys » Sat Feb 17, 2018 10:52 am
I would bet that the #1 soudnbite is actually not the same length as #2 and #3.. track groups on soundbites only work when they are exactly the same length. that's why it starts working when you make a cut. I'll try this out today and check it.
mrgkeys
Postby stringtheory » Sun Feb 18, 2018 10:52 pm
eh, you’re probably right, even though i’m pretty sure i created the soundbites in away that would have made them the same length...thanks.
stringtheory
Return to Digital Performer [MacOS]: Troubleshooting/Criticism
Who is online
Who is online
Login Form
