Bounce to disk problem
Hello, This problem is driving me CRAZY!!! Im trying to bounce my final mix down. Song starts at bar 3, I go to the track menu select bar 1 thru 117 on all tracks giving about 10 bars after tune ends. When bounce is complete the bounce starts after bar 3. It happens intermittently! I usually restart computer. Sometimes this works. Does anyone have a solution?
Thanx
Thanx
DP 7.01, 2 x 2.66 GHz Dual-Core Intel Mac 4 GB ram ,Macbook 2.16 1.5 GB ram, Motu 896HD, Motu Ultralite, Powercore compact, , Reason 4.0, M-box, , MiniMonsta, UAD 2 QUAD, B4 2, Stylus RMX Guitar Rig 4,Battery 3, Universal Audio 6176, UA M-610, 2 Chandler Germanium and Germ Comp, Akg 414, Rode NT 1, Pearlman TM1, Royer 121, Cascade Fatheads 2,Rupert Neve Comp
Re: Bounce to disk problem
It's a known bug. Best to print the mix in real time or start the bounce at bar 1 and then trim as needed after.
I'd suggest adding which version of DP you use in your signature.
Have you repaired permissions recently? This happened to me (and a few other people, if I'm not mistaken) a couple of times after installing new software, but repairing permissions and restarting fixed it.
iMac Intel Core i5 3.2ghz - 16gb RAM - OSX 10.10.5 - DP 9.01 - Mach Five 3.2.1 - Ethno Instrument 2.0.3 - Kontakt 5.4.3 - 4pre - 828 original - micro express
Thanx for the replies!!! I do start my bounce on bar 1!! I am running DP 6.03. How do I repair permissions on my Mac?
Thanx again!!
Thanx again!!
I figured how to repair permissions!!!
Thanx!!!
Thanx!!!
Get ONYX... it does it all in one fell swoop!shuld wrote:I figured how to repair permissions!!!
Thanx!!!
Okay. Sorry, I thought you were starting it at bar 3. Put some blank audio on one track at bar 1 and maybe that will get it to start bouncing before bar 3. Or move you entire session to a later time. That is, of course, if the repairing permissions doesn't work for you. Never worked for me. You never know when that bug (and it is a bug) will pop up. I've gone a month without seeing it and then all of the sudden it will show up. Now I print mixes in real time, most of the time.shuld wrote:Thanx for the replies!!! I do start my bounce on bar 1!!
Yeah I start bounce on 1. Music starts at bar 3!! I repaired mu permissions! did not change a thing. I bounced in real time. No Problem!!!
Thanx again guy's
Dave
Thanx again guy's
Dave
