strange results in Scale time
I'll take any suggestions you might have. The first image shows show the entered info.
The second shows the results. This should have shorten by 00.04.00
Mac Pro 4,1, OS 10.9.5, 2.93 GHz Quad-Core Intel Xeon, 32 GB 1066 MHz, DP 8.07, Apogee Ensemble, UA SOLO 610, Euphonix MC Control & MC mix, JBL Monitors, Ocean Way Drums Gold, Komplete 7, Waves Classic Studio Bundle,Stylus RMX, iZotope RX,1TB glyph Drive, Carvin 6 string Bass
http://www.HorizonEntertainment-NC.com
Re: strange results in Scale time
Looks like I have found a error in the programing. Was able to get the hour+ wav file to tech support and they came up with same results.
reply: " have reproduced your issue and at this point, have not found a fix. It looks as if this needs to be brought to our development team for further investigation. I will keep you posted on any news, but I would not expect an immediate solution."
What a way to make a person insane thinking it was something I was doing wrong
Good job on documenting and getting that to tech support's attention. You've done us all a service.
MacBook Pro retina 2015, i7, 16GB, DP 10, M4
- Shooshie
Ayiyiyiyi! That's bad news. I hope they fix it soon. I need that.
Shoosh
- bralston
I wonder if this adding of time is also related to the same reason (similar code) when I bounce a selection of measures to disk with a QT video as the output...it also adds time to the end of the file with blank/black frames at the end. (Yes...I reported it). Hmmmmmm........
Regards,
Brian Ralston
Brian Ralston
I tried a full project freeze (all audio files) which makes every file the exact same length unless I am misunderstanding something.
But the point is I tried a full project scale time with these frozen tracks and the results were all over the place as far as length after processing
Oh boy. We need that big time.
Help us obewon magic D
Yeah, that's a bad bug.
Meanwhile, Melodyne can be your friend in situations like this. That's
what I use to time-scale audio anyway.
http://www.davepolich.com
... Or IRCAM in MachFive.
Interesting. Explain?MIDI Life Crisis wrote:... Or IRCAM in MachFive.
Is the Melodyne quality, the results, worth $400.00. It looks like maybe the editor could do what I need
IMO, Melodyne is indeed worth every penny, and then some. I'd pay $499 for it.jbyerly1 wrote:Is the Melodyne quality, the results, worth $400.00. It looks like maybe the editor could do what I need
For me it is not an option, it is a necessity. There are numerous projects
I have done which could not have been realized without Melodyne.
Thank you for the the opinion. This is the only place I would actually listen to an opinion about software
I agree with David about the value of melodyne.
